- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Iphone support for KDL-40lx900
I wanted to control my KDL-40lx900 from an iPhone app, and was supprised to leard tha this is not supported for my tv. A google search gave no mantion of a firmvare ugrade for my model that would allow for this. Can this be true in 2013, or is an update pending?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes the Sony app unfortunately doesn't work with this model unfortunately, however you could try using 'Zeebox' or 3rd party apps as these might offer a degree of control?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, but those apps require that you mount ir-hardvare and that defeats the purpuse. Both my TV and my iPhone is connected to the same LAN and should be able to communicate that way.
it is not a low end tv, and I foolishly expectet sony to upgrade the TV as new tech became avalable.
Even my cheap set-top-box can do this???
Message was edited by: mortenpiper
