Is there a way to turn off the idle tv standby
GELÖST
profile.country.en_GB.title
Star65
Besucher
If there is can you tell me how i have a bravia  tv
16 ANTWORTEN 16
sebastian1001001
Neues Mitglied
i have a sony bravia model number kdl-40z4500 and i went on to home, settings, features, timer,off and it wont switch off i really need help
Anonymous
Nicht anwendbar
Hi
According to the manual:
If you switch off the TV and switch it on again, “Sleep Timer” is reset to “Off.”
Cheers
Shalamar1963
Entdecker
Nothing I've tried works please help
Altin901
Entdecker
For me it worked by using uper button at the same time on/off button then unplugged the power cable all together. It works !!!
It has drive me crazy as I try it all the options which are shown in here.
I guess cut all the power and restart always works.
Rockiiocean
Neues Mitglied
It took a while but here it is.
Select the HOME> select SETTINGS> POWER> ECO> IDLE TV STANDBY > select OFF
Let me know if this worked for you.
Rockii
TandemBrian
Entdecker
 All auto sleep/ECO settings are disabled, turned off,  but if I pause a streaming playback, then after 5 mins, the TV goes to standby.  On restart, I have to navigate to load the app and find and restart the stream all over, nightmare! Bravia XR 55A80K model.  with latest auto-software installed.
TheRealOG
@TandemBrian
Double check these settings: The TV turns off automatically
