Hi Everyone.
I'm looking to see how you reset a KDL-32EX524 to Factory -New settings like it just came out of the box untouched.
Over here, we press the UP ARROW on the TV's remote, then walk up to the TV and press the power button on the TV set. Once released, the TV shuts down then reboots. Then it's completely reset, like you just brought it home from the store.
If you go to the settings menu, then I think its under general options. Your manual will give you precise details on how to do it though for sure...
Thanks
