- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all,
Was wondering if somebody could tell me what WiFi widget is compatable with the KDL-40EX403, I recently purchased a TP-LINK TL-WN722N 150Mbps widget which is no good as not compatable and cant find a way to install any drivers, so if someone can point me to one I would be grateful, failing that is it the RJ45 LAN cable I need as opposed to the RJ11 which I read is incorrect cable for this connection ?.
Many thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You need to use the Sony wireless dongle.
http://www.sony.co.uk/product/tpa-other-tv-accessories/uwa-br100
Alternatively get a pair of homeplugs
Indeed any Ethernet cable will be fine. RJ11 is a modem cable so no the same thing.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks will give that a go, possibly hardwire because will save any problems.:smileywink:
