- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2017
October 2017
KDL-50W805B Standby light flashing red 3 times, not turning on
Hi, tv is 3 years old and the standby light is flashing red 3 times and not responding to remote, or turning on. Why is this and how can it be fixed?
TV Model is KDL-50W805B.
Please help. Thank you.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2017
October 2017
Hi @ChrisMc14ch and welcome to the Community
The red light flashes when a TV has detected an issue or problem.
I believe 3 flashing red lights means either a bad main logic or power board.
(Which would match your symptoms of no power.)
You could try a power reset on your TV to see if that fixes it, however
usually this kind of problem can only be fixed by a repair.
Do you have any warranty left on your TV?
Either way I would give Sony Support a ring on +44 (0) 2073652810
