Pictures
OPGELOST
profile.country.en_GB.title
vmpatel
Bezoeker
Pictures
I Have Sony Bravia KDL 20S2020
I get sound but no pictures
Any help to get the pictures on the TV?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Anonymous
Niet van toepassing
Hi there
This to me sounds like a hardware fault. Possibility of backlight. Or maybe sometype of power inverter. However, I would unplug the TV from the wall for a while, then plug it in again, as this may clear some problems if it isnt a hardware fault.
If it doesnt fix it, you have 1 of a couple of options
1 - Contact a Sony repair center and find out the cost of repair.
2 - Im going to assume though that the cost of repair will be un-economical to fix, your best bet is to replace the TV.
Hope that helps
1 ANTWOORD 1
Anonymous
Niet van toepassing
Hi there
Hope that helps
