Screen Problems
profile.country.sv_SE.title
JohanStudentUppsala
Visitor
Screen Problems
Hi!
I have a Sony KDL40CX520BAEP 1 LCD TV, recently purchased. The thing is that it is no longer working, this morning I couldnt turn it on. I have followed the instructions in the manual which says to count how often the red light flashes in a sequence, which is 8. I do not know what this means, any ideas? Sometimes I get to the start screen, which says Sony but then despite the green light nothing shows up. Its just blank.
So anyone knows what this means?
1 REPLY 1
profile.country.en_GB.title
Bravia55HX
Member
Hi,
its would seem that its a voltage problem, and since you only just purchased this you should return to your dealer and let him sort it out for you.
