Hi i want to buy my grandparents a tv however it needs to be setup so can listen through headphones and without at the same time. Is it possible to do this with the sony bravia kdl-40Rd453 and the sony hdl-32hx753? Help would really be appreciated on this matter. Doesn't have to be fancy or have all the latest features just really good sound an picture. Thanks in advance
Hi there
Yes it is possible to get audio from both the headphones and the TVs internal speakers. You will need to connect the headphones to the TV and then go into the TVs settings and set the 'Headphone Speaker Link' to OFF
For the KDL-40RD453, see page 25 of the manual : HERE
For the KDL-32HX753, see instructions ; HERE
Cheers
