- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
The alphabet keypad on Bravia remote control
Just got myself KDL32EX723 which is fantastic and absolutely keen on its widgets. I have been trying
to use both Lovefilm and Youtube, and search the content.
The difficulty I have is that the remote keypad does not respond to the alphabets. The instruction refers using the TV/text mode button but this only allows to use which connection port to use.
Could anyone tell how to activate the alphabets on the remote control so that the text can be entered
on search functions?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you use the remote when in the dedicated Youtube application or via the browser - I think it will only work in the application.
If you have a smartphone there is an app called Media Remote for iOS and Android which makes things easier still.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How do I shift from numbers to text on the remote control
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Rubycidi,
in the on screen keyboard (different in a different Apps/Menù) there isn't a key like "123/ABC"?
Manolo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you don't have an on screen keyboard you can try to use te colored key (Red, Green...) on remote to change the numeric key function.
Your TVs model?
Manolo
