TV Supported Refresh Rates
SOLVED
profile.country.en_GB.title
Bond28
New
Hi
I have built a home theatre PC to connect to my tv using a HDMI cable.
I need to set the correct refresh rates on the PC that best fit those supported by my tv.
I cannot find the supported tv refresh rates in the instructions or online.
My tv model is:
Bravia KDL32EX403.  What are all of the refresh rates that this tv supports?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
if it helps, the monitor settings on my laptop is set at 60hz and this displays  perfectly on a 43" plasma and on my sony.
1 REPLY 1
Bravia55HX
Member
Hi,
