USB Ports no longer working
profile.country.en_GB.title
tonbrisc1
My USB Ports on my Bravia KDL46EX723 have stopped working. The last time I used them was before the latest update, when I tried to view some photographs yesterday on my USB stick, formatted FAT32, I couldn't see my photographs and I also noticed that the power light on the USB stick was not illuminated. I tried the stick in both my USB ports and neither was powered. I have tried a Factory Reset, different memory sticks, nothing seems to work via the USB ports. I have checked to see if there is a newer Bravia update and I am running the latest version. The Memory stick is working ok in my computer. What are my options please?
Reason for edit,   Spelling mistake.
Message was edited by: tonbrisc1
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Bravia55HX
Hi,
this has been reported on here before and the end result was a replacement motherboard by Sony, i would strongly suggest you contact your nearest Sony authorised repair centre for further clarification of your particular problem.
5 ODPOW. 5
Bravia55HX
Hi,
tonbrisc1
Thanks Bravia55HX923, for the prompt and helpful reply.
tonbrisc1
Update.
Had a new motherboard fitted today, USB Ports working correctly now.
Thanks again for the information.
Strongboy0
Did you get charged for this and how much?
Anonymous
Nie dotyczy
@Strongboy0 - seeing as this is over 4 years old, even if the person replied back, things/prices would be different.
Only a repair centre can diagnose the problem and hence price of repair,
