Just joined. Have Bravia KDLNX713U TV. Very pleased with it. Have accessed the widgets a few times so far but not over the last 24hours. Flickr says it can't refresh data, etc.. I have looked through the posts but there doesn't seem to be a definitive answer. Some talk of resetting software, but doesn't say how. I can access iPlayer fine so the internet,(wireless), access is OK. What can I do to get the Widgets to load correctly? Can Sony help? Many thanks,
Johnmlowe
Message was edited by: johnmlowe
Welcome to the forums.
Im not overly familiarr with the Yahoo widgets myself but from experience sometimes theset things can just be temporary glitches rather than anything serious. Make sure you have updated the firmware on the TV ( link at the top of the page). If that doesn't then work, and its still not working after a few days, just try a factory reset of the TV, under the settings menu on the TV which should flush anything thats glitching on the TV.
Do feedback on how successful this is though..
Thanks
