I have an A317S and all of a sudden my laptop won't start. When I press the power on button nothing happens. I've tried it with the battery in, the battery out. AC lead in, AC lead out, everything I can think of. But there is no life at all, no flickering lights, no hard drive spin, no fan, no nothing!
Does anyone have any ideas at all why this could be happening? I've heard it could be to do with the RAM but I've no idea where the RAM slot is, could anyone point me in the right direction for this?
Thanks
Thanks
This is worrying.. 2 people seems to had the same problems... with the same model as mine
Thanks for your help, will try & changing the RAM card around. There's 2 slots so hopefully changing slots may help. Have had it only about a month. I'm just hoping I don't have to send it back to Sony.....
good luck
Yeah it's worrying but you have to stay positive.
3 weeks and your taking the back off? why not send it back..is it a lorry laptop that was damaged as it fell off?..are you one of the new house repairers off with the woof ... with shirt sleeves down..its a computer ..till you load the screen and keyboards with postits ..then under clear tape( so value is the infomation isnt lost).. you are to load more work on a duck..ps never store passwords under clear tape like others yeh!! or eat yellow snow.:smileyflag:
Good point though, don't take the machine apart if it's in warranty
