For some reason vaio update 4 informed me that an automatic update from months back suddenly needs to be installed: vaio information flow sample music.
Trying the auto update I keep getting a message that the auto update failed try manually, i did this and now I have lost "vaio information flow" altogether, at no stage did anything install. Where can I get Vaio Information flow from and is it important?
Just to clarify need to find vaio "information flow" not "vaio information flow music".
Hi bps1,
have you tried a system restore to a point before you installed the Information flow update.?
As to the VAIO Information Flow Sample Music 2.0.00.13230 update appearing again I'll ask Sony support to investigate this..
yeah it hasn't worked, do you if it is available on the us website do you know what AR31S model is in the states.
