I can't read the downloaded manuals - and I don't know if there is a pc card slot or whatelese i can do. My sound has a saffire pro soundcard that only has firewire connections. I need a way o connecting to his new laptop.
Solved! Go to Solution.
Hi padavie35,
welcome to Questions & Answers..:smileyhappy:
As can been seen by the image below your vaio does not have a firewire or an Express card slot..
It may be worth a visit to maplins to see if they have some kind of adaptor that you could use..
Thanks for taking the trouble - and yes, you are right. Maplin were surprised that Sonywas producing a laptop without firewire - and their solutions involved PCMCIA and so on. Another solution they thought might be a usb 3 to firewire - but not available yet. Thanks
Hi padavie35,
I think you'll find that Sony are not the only manufacturer to move away from firewire..
Suprised there is nothing on the market yet, hopefully someone will identify the need & produce something soon..
