I have a Vaio RX201. Would like to get DVD burner for editing home video. Is it better to change CD-RW drive, ie is this easy to do, and change the little panel at front, or go for an external model via Firewire connector(easier but costs twice as much!!)
Any suggestions of models, Sony, Pioneer, NEC
Is the graphics card easy to change?
Thanks
Apparently it's not easy to change the drives as the sizes don't always match.
If you do, go for something like Pioneer or NEC
As for the GFX it's a doddle.
hi
whats rong with the one that cane with your rx ?????
hi
They are once you get it in the bay.
ohh im getting confused i thought the rx series is newer than the rs
isnt the rx the one with the little dip in the top ????
i dont know how your pc comes apart but on mine it is fairly easy to change the drive
you have to obiously take the chassis of the pc and then to get to the front of the bay i had to unclip 8 clips for the whole plastic front bit of the pc then you just slide the drve out
RX then
RS then
RZ, finally
RA - just coming out - all black, well specced - too expensive!!
Yeah not cheap at all.
it looks amazing though doesnt it
it was in this months inmac mag you have to ring to get a price though which means it is a preorder
Or you can go to Apple Store.
