Cracking noise on my Sony Vaio T13
profile.country.fr_LU.title
Rui-Vaio
Visitor
Hello,
I have serious problem with my Vaio-T13.
A weird noise coming from the right side of the laptop began a week ago and everyday the noise was louder.
Like cracking... Toc, toc, toc... Like somthing jumping around inside...
Yesterday the noise was even louder and i was not able to switch the laptop off. Today i tried to start it again and and after a few intents it worked, but I could not do anything with it and finally i shut down manually...
What can that be? Hardidsk?
It has only 3 months... Is that possible?
2 REPLIES 2
Blencogo
Hi Rui-Vaio and welcome.
From what you say, it does sound like a hard drive problem.
Although unusual, hard drives do fail and they are still susceptible to little knocks and bumps.
I would contact Vaio Support as a repair may be required.
Support (at the top of this page)
Online Support
Contact Us
Vaio and Computing
You will need to enter your Vaio's Serial Number to get contact options.
:slight_frown:
Rui-Vaio
Visitor
Hi Blencogo,
I hope that the warranty will replace the harddisk or wathever it is...
The only problem is that i am now working in Nicaragua and i bought the laptop in Luxembourg Europe.
I do not think that they repair it here 😞
Thanks for your answer
