dell pc to bravia tv no colour ?
SOLUCIONADO
soulalways
Novo
hi guys,
not sure if this is the correct board..?
all of a sudden my pc to bravia is showing no colour on tv screen..?
have 2 hdmi cables,tried both in 4 ports but still no colour..
i have a sharp tv in bedroom and pc works as normal when connected with either hdmi cable.
so process of elimination the problem is with my sony bravia model .
KDL-40W605B can someone please advise as i have tried everything in settings.
many thanks
1 SOLUÇÃO ACEITE
Soluções aceites
soulalways
Novo
hi iamnic,
thank you for your help,but i updated my dell with new ups 7 in total and hey presto its back to normal!
Ver solução na publicação original
2 RESPOSTAS 2
IamNic
Hello @soulalways,
maybe somehow your graphics card settings were changed to have the color saturation on 0 for when the TV is connected - said setting won't carry over to other displays connected which may be the reason it only shows up on the Sony TV.
Kindly right-click on your desktop and enter your graphics card control panel via the dropdown menu. There you should find some type of color/saturation setting.
- Nic
soulalways
Novo
hi iamnic,
