Hello I´m a new member of the Vaio Club
I have a Problem with my notebook.
Sometimes my display makes a refresh.
The Display is for a little time black and after tihs situation the Windows Display its all right.
I thing this is a driver Problem. In the setting is the Display "Standard pnp"
Can you say, waht can I do?
Regards
NetRasta
Go to control panel - vaio control center - display - display settings. On the FE41Z you should check that the resolution is set on its highest (1280 x 800) and that colors is set to 32 bit. Monitor should be generic pnp on nvidia geforce go 7600.
If it only happens when launching / quitting applications (especially games) ensure it's not just an adjustment made to the screen resolution by the software you're using.
If not that, try advanced settings - monitor - driver - update driver (ensure connected to internet first). Unlikely to work but worth a look.
Good luck.
thanks but settings are all in this type.
but I see the monitor is Windows Standard Monitor without colour settings It´s that right?
Good luck.
