Driver Downloads Not Found Error ??
NINJA-THEORY
Explorer
Hi im trying to get drivers for my Sony Vaio Model --> VPCSA2C5E from the link below but everytime i click download i get this error
An error occurred while processing your request.
Reference #132.a4023e17.1562815251.b4b04c3
i need this driver VAIO Update (Windows 7 32bit/64bit) and loads others can someone at Sony tell me why i keep getting these errors are you removing drivers from your support page ? if yes how do i go about getting drivers that come preinstalled on the laptop ?
http://download.sony-europe.com/PUB/VAIO/Updates/EP0000260866.exe
https://www.sony.co.uk/electronics/support/laptop-pc-vpc-series/vpcsa2c5e/downloads
2 REPLIES 2
Sean_Mc
Moderator
Hi there,
Can you try the following link here.
Let me know how you get on.
Best wishes,
Sean Mc
Blencogo
Is it just this driver that won't download?
I think this old version of Vaio Update (Ver 5.5) is no longer supported and does not work.so, I guess, it has been removed from the download server.
My Vaio VPCSB started life with this same Vaio Update Ver 5.5. I am still using Windows 7 but Vaio Update has been replaced and updated (probably by Vaio Update itself) to version 7.4.0.15200 and this version supports all versions of Windows from 7 to 10.
If you Google for this version, you will find a download - I think it is EP0000605020.exe
https://www.sony.co.uk/electronics/support/downloads/00016198
I have no idea if this is an update only or if it can be used an a clean install - I guess you would have to try it ..... at your own risk!!!!
