file transfer from windows 7 to 8 problem
I had a Lenovo Thinkpad of Windows 7 and thanks to Currys it broke. I had used the Lenovo backup system to back the files onto an external HDD. I have had it replaced with a Sony Viao on Winsows 8 and am completely baffled on how to transfer the files onto my new laptop, can anyone help?
Jan
1 REPLY 1
jumpsuit
Hi there and welcome to the Community :slight_smile:
When you say you backed up files did you use specific software to do this?
(for example Lenovo's OneKey Recovery.)
Did you make an image file, ( e.g. a copy of the whole system) or did you just copy files / folders across to the external drive?
