I'm using model Sony VAIO VGN-NS10L and when my VAIO centre checks for updates, it shows the graphics card has a new version to update. I run the installation and it seems to complete successfully until after the laptop restart when I get the error message it has failed to install in the VAIO centre (as shown below).
I am unsure whether this is because I upgraded my operating system from Windows XP to Windows 7 before and the driver update is now incompatible!?
Many thanks in advance to your asnwers
Solved! Go to Solution.
Hi virwong and welcome.
8.15.10.1872 is a Windows 7 driver for the Mobile Intel(R) Graphics Media Accelerator 4500M. Looking at the support pages for your model, I see this driver comes in both a 32-bit and a 64-bit version. How big is the downloaded file? The 32-bit version is 60.19Mb and the 64-bit version is 78.8Mb - check you have the correct version.
Another explanation may be that this driver is already installed. Check the version of the installed driver to see if it, or a more recent version, is already installed.
You could try downloading the correct driver manually fron the support website here: -
http://www.sony.co.uk/support/en/product/VGN-NS10L_S/updates
Alternatively, you can download the latest driver from the Intel website.
You may be right that Vaio Update is misbehaving because you have changed the OS but in the end, all you need to know is that you have the correct driver installed. If it is then you may need to just ignore this update suggestion.
