Heat problem?
vikalek
Visitor
Heat problem?
Hi people, could somebody help me please. My vaio PCG-Z1RMP is freezing when the CPU ventilator starts working only solution at this time is to turn off. After 10 minutes I start it again and work for a while and it's happens again and again and again. Service said, LCD is the reason, I can belive that. Do you, have another explanation. Thanx for reply.
20 REPLIES 20
profile.country.de_DE.title
itbroker
Visitor
This is resembling a problem of Hardware. Did you contact the e-support?
rich912
Contributor
Welcome to Culb Vaio Vikalek.
Download Mobile Meter and check the CPU temperature.
Go n-éirí an bóthar leat
vikalek
Visitor
Thank you for greetings and recommendation for mobmeter, in my first post i've writen "can belive that" of course I mean "cannot belive that" it was my mistake, sorry. Results are: freez at 41 degrees Celsius and tempertur don't rise above 55. But for all that if the ventilator starts working, notebook don't respons.
vikalek
Visitor
I have tried to register at e-Support but it's not functioning. I haven't got a Access e-mail.
Twisted-Rizla
Visitor
Give Sony a call. You can get the numbers from here
profile.country.en_GB.title
kee-lo_
Member
Well your tempretures are pretty good.
vikalek
Visitor
OK, what is your suggestion what can be fault.
vikalek
Visitor
Thank you very much Twisted-rizla for this advice, but I would try it in forum. Nobody knows may be I meet an expert.
kee-lo_
Member
I have no idea, I guess it could be a bad install of Windows or a peripheral you use with the VAIO
