Hi.. just bought this today needed a new hard drive.
Anyway I have fitted a HDD downloaded the wireless driver with my other lappy usb installed onto the vaio then downloaded slimdrivers on to the vaio for the rest of the drivers..
Just noticed the Radeon is nowhere to be found on this laptop search brings no results and its not in device manager..
any help would be appreciated :
P.s I have tried to download the Radeon drivers and it just brings up an error message when I unzip or open the download
Message was edited by: rsvmad1
Hi rsvmad1.
What version of windows have you installed?
You need to download the AMD graphics driver from the Sony Support website for your model here: -
http://www.sony.co.uk/support/en/product/VPCCB3P1E_B/updates
Version 9.1 for Windows 8 or Version 8.85 for Windows 7.
Follow the instructions to install the downloaded .EXE file.
