Hi
I have make a new installation of the VISTA;
This time i would like to make a Recovery Disc.
But the VAIO Recovery Center is not accessible
How can i do ..
thanks for help
Hi armir73 and welcome.
If you make a clean install of Vista you will lose all the Sony software including the Vaio Recovery Centre and you cannot make Recovery Discs. You should have made Recovery Discs before you made the clean install.
You may still have the Vaio Recovery Partition of you have not formated the whole drive and you can start the Vaio Recovery Centre by tapping F10 during boot.
If you want to have a back-up of your new Vista system you will need to buy a disc imaging program like Acronis True Image 2010 which will keep a copy of your entire hard disc that can be used mounted or unmounted to reinstall your whole system or just a single file.
