Hello,
I usually use my notebook for work, but I have one game which I play quite often: Fifa 2004.
I just installed it in my recently acquired vaio and I have a problem. If I press 2 arrows at the same time while pressing another key, only one of the arrows will work.
Is there anything I can do to solve this?
Thank you
The only way I managed to defeat this problem on my old Tosh was to use an external keyboard
Isn't there any software upgrade to solve this? I had never seen this happen on my past laptops ...
Not that I am aware of.
I have heard that with USB Keyboards 3 keys max can be pressed at any one time.
I would imagine it would be the same with Built-in Keyboards.
If you have a PS2 Port on your laptop, i recommend you buy a PS2 Keyboard and use it if you are really desperate.
BTW, I don't know how computer literate you are, When i say PS2, i dont mean the Playstation 2, PS2 is a little keyboard/mouse socket.
