Hi all,
I am trying to hook up my Vaio FE11H to the TV.
I have used the s-video port from the laptop going to the s-video on tv. I am seeing a black and white picture and no sound.
Can any recommended the best way to sort this problem out? I am a novice when it comes to setting it up so a quick run down would be much appreciated.
Many Thanks
First of all you need to be sure that the standard TV settings are the right one - I think you need to change this standard from NTSC (in US and Japan) to PAL B or Pal D. If you still have this kind of problems after this changes, let me know.
I got the s-video to s-video to work ok, but I don't get the sound on the tv.
Instead I get the sound coming from the laptop, but the tv is silent.
Got a 3.5mm to L-R adapter connected to the headphone out, and then the L-R's from the adapter connected to the L-R on the tv.
Am I missing a setting or something?
/SSB
Tried to delete the post above but wasn't allowed due to it being older than 0 days.
Anyway, problem solved. Plugging the speaker stuff into the correct holes really help :smileyblush:
My VAIO SZ4MN/B only can e connected to LCD TV... any idea if I want to connect it to conventional TV????
Hi There
I linked My Laptop up to my TV recently and ever since the display on my laptop has changed, It does not stretch across the whole screen, there is about an inch black line either side..
Not sure what i've done to it,, Anyone know how to get it back to full screen,,
Thanks
I have a Sony Vaio VGN-NR11Z/S and my TV is a Brand new Panasonic HD ready.It has some kind of PC plug on it....do I just need one cable to connect the two? Does anyone know which one? Thanks very much!
Hi friedbergdvah and welcome.
I think you need a normal D-Sub 15-pin Monitor Cable like this one: -
http://www.amazon.co.uk/HD15M-Quality-Monitor-Extension-Cable/dp/B000747OFS/ref=pd_bbs_6?ie=UTF8&s=g...
If you want sound, you will need to connect your headphone socket to your TV audio in. You will need something like this: -
http://www.amazon.co.uk/Profigold-BA-PGA3402-Stereo-Audio-3-5mm/dp/B0000BX71S/ref=sr_1_1?ie=UTF8&s=g...
Hi there,
I have the same problem with the black and white picture in my TV. I connect my Vaio FZ with the Tv via S-video (S-video out to S-video input -my tv has S-video input-), and the tv has black and white picture. It is strange because I bought my laptop on august, and I could watch Tv perfectly, but I have this problem since December.
I have try a lot of things, and it is more strange: When I install a new driver for the Nvidia 8400m gt (original driver, new driver from Vaio Update, drivers from laptopvideo2go) the first time I start the laptop, I have color on my Tv; but when I reestart the Laptop, the color has gone: It is again a black and white picture in my Tv. And it is a problem been installing a driver when I want to watch a film in my Tv.
The signal configuration is Ok ( Nvidia Control Panel launch an S-video PAL b/g signal -I am from Spain, sorry for my english-), so I Think that the problem could be the configuration of Windows Vista or Nvidia Control Panel, something I have touch, but I don´t know what.
Apreciate your help.
P.D.: If you have the B&W Tv problem, try to reinstall a driver (whatever for your Nvidia graphics card); maybe you could watch a color picture on your Tv the first time you reestart, like me.
