Media Player & Remove Program errors
PainKiller
Hi, my SZ3XP works fine with Vista except "Window Media Player" and "Remove Program". It takes 5 to 10 seconds to start and change the songs, the sound lags occasionally. After reboot several times to finish install programs, I cannot remove any program in the "Uninstall Program" tab; it looks like all programs were disabled to be uninstall. Does anyone have the same problems with me or does anyone know the solution. Thanks.
0 ODPOWIEDZI 0
