My sony vaio SVS1512Z9EB can't play one audio CD
ekettemann
Hello,
I purchased the sony vaio SVS1512Z9EB last June and so far it worked perfectly. Today I bought an audio CD and it simply doesn't recognize the CD. I can ear the CD running for a couple of seconds and then it stops. I tried the CD in an other computer and it worked, as well as other CD's and DVD's on the issued laptop and they run normally. Any suggestion?
Thank you
1 ODPOWIEDŹ 1
takrzem
It does happen sometimes unfprtunately, however I usually have similar issue with a few CDs that my stand-alone CD player neither does want to acknowledge nor recognise nor allow me to choose the tracks I want to listen to if it recognises it eventually.
What's the CD in question? Is this just an Audio CD or hybrid one (with other content: videos etc.)?
If that's just this once CD that causing the problem, maybe it would be worth trying another copy / replacing it?
