No sound via internal speakers? VGN-SZ2XP
mike_coreit
Member
Hi I have a VGN-SZ2XP notebook and after switching it on one day I can't get the internal speakers to play any sound. I can attach headphones/speakers through the jack and that works fine, what could be wrong?
4 REPLIES 4
mike_coreit
Member
Anyone got any ideas?
mike_coreit
Member
Could this be due to the material that the speaker cables are made of?
profile.country.en_GB.title
sohisaba
Visitor
Same here.
tryed so change
14pin (whute) ribbon cable
Power button board with different speakers and main ribbon cable
I think it's hardware problem. very frustrated.
tryed to run Linux W7 and Xp didn't work non of them. only able to get sound from headphones
did you get any solution ?
mike_coreit
Member
Hi, I do remember this was a long time ago. I tried the same steps as you did with the ribbon cable and logic board, though I didn't have any success.
I couldn't confirm the exact cause of this issue, though in my case I think it was an issue relating to the motherboard.
