No TASK MANAGER
roryjnr
No TASK MANAGER
After reformatting my VAIO system I am unable to access my task manager through Ctrl + Alt + Del, Start > Run taskmgr.exe or right-clicking task bar > Task Manager.
I believe this is one of a few problems.. I also encountered problems installing the iTunes software after downloading it.
Help please.
Thanks.
11 ODPOW. 11
profile.country.en_GB.title
kee-lo_
I am baffled.
Have you done a full Spyware scan?
roryjnr
Well I doubt I could have any spyware.. I just reformatted with a deletion of everything.. Apparently, anwyays.
I can't install my updated version of Norton either because this PC is so crap lol. Sony is beginning to really suck..
I cant have Spyware, can I? I just reformatted lol.
kee-lo_
You can get spyware in seconds of being online without protection
TygerTyger
Yes you can. If you can't find any spyware or viruses and you've only just formatted I'd just try doing another recovery. There's not an easy way to repair problems with Windows other than that.
kee-lo_
Info on this topic is scarse on Google too
roryjnr
Spyware doesn't just 'appear' on your machine.. Does it? I always understood that you have to actually download something or Accept a file or something.. I know are probably some sites that can inflict Spyware on your PC, but the only sites I have been on is this one here and Google (where I searched for this site).
Oh and the iTunes site and Symantec site. That's it..
So you guys recommend 'another' reformat?
rich912
For whatever reason, Task Manager may have been disabled in the Registry.
There is a Regedit tweak available here that will enable the Task Manager ¿ Line 51, right hand side (you will have to download with IE as Mozilla doesn¿t work with this).
Go n-éirí an bóthar leat
roryjnr
Thanks for that :). Do you think it will work?
Either way I'll post my results up here after trying it.
rich912
Only if this is the problem!
