When I switched on my SONY PCV-LX2 today I was presented with the following message:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
It then said put in the WinXP CD and press 'r' to repair.
But the product recovery CD-ROM supplied with the PC does not have this option. What should I do as I do not want to do a complete recovery and lose the data on my C drive.
Thanks
David Seabright
I think you can use the XP setup floppy disks from Microsoft to run the recovery console. They are at XP Home and XP Pro
Then follow the instructions at http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B307545
I've never tried it though so can't be sure it'll work - I'm lucky enough to have a couple of full install disks.
Thanks for your reply but it won't work. Have already tried it with the XP Pro installation disk!!! If you notice on the Microsoft site it says:
'Warning Do not use the procedure that is described in this article if your computer has an OEM-installed operating system. The system hive on OEM installations creates passwords ........'
However, Microsoft does not go on to say what to do if you do have an OEM installation!!
Cheers
So when you put your recovery CD in there's no option to boot into the XP Recovery Console?
No!! You can only do a total restore that re-partitions the C drive.
Just had a reply from Sony's e-support saying that a recovery is the only option - which re-formats the disk!!:smileysad:
Lucky I have back-ups - it's just the hassle of spending the next few days re-installing everything when I have better things to do!!!
Thanks to all that have viewed and responded to this message.
If anyone does have a solution I would love to hear as I probably won't re-install until the weekend.:smileycry:
Sonys method of installation doesn't usually leave many options for doing it your own way so I suspect it really is the only way. Congratulations on getting e-support, in all the time I've been here you are the first person I've seen get it to work.
God that sucks.
They should have the recovery console for advanced users.
They should also make it easier/possible to have XP Pro/something else without asking at the forum and praying it works.
