I have a PCV-RS 504 with 1GB RAM, and want to take it to 2GB.
Actual Slots 1 and 3 house 1x512 each; 2 and 4 are empty.
I bought 2 x 512MB DDR400 and placed them in empty slots. Power up is ok, and BIOS shows 2GB RAM,
BUT after I work for a few minutes the PC freezes. Nothing moves, only way out is hard power off.
Can anybody give me some help?
Thanks, franco.
Solved! Go to Solution.
Hi Franco,
Try reseating all RAM – just in case there is poor connection.
Also, are the four modules identical in specification? This normally is not a problem but may possibly be the cause, or you could have one faulty module or slot.
Assuming that the supplier of the memory has a no quibble returns policy you may wish to consider purchasing two 1GB modules and place them in slots 1 & 3 – they are quite inexpensive...
Rich
Hi Franco,
Rich
