Hello!
I have a problem ...
Maximum memory on a laptop VAIO PCG-K315M 1gb
I bought two 512 MB memory pc-2100 sodimm installed in the laptop, but the laptop shows that costs only 512, though the program "Everest" says installed two 512 MB memory ...
Then I went and bought just in case two more memory to 512 megabytes, but pc-2700, but nothing has changed ...
Installed memory Pc-2700 at 1 gigabyte, but it shows that only allows 512 megabytes ...
Tries to call in those. support, but unfortunately did not work, then the receiver will not take, then sent to a service center, and there do not take up!
I need all-only consultation, how to do so to show the 1 gigabyte of memory!
In Bios and windows!
In advance, thank you very much!
Where are you getting the figures from?
Read the installed memory figure from the Windows Operating System - not from some external program: -
Start -> Control Panel -> System
On the 'General' Tab at the bottom, how much memory is Windows actually using?
