Problem by using wlan over 2 pc's
aalen
I've got the notebook VGN-AR11M, the problem is, when somebody from my family connected to the wlan, my notebook can not longer use the wlan. What is the Problem ?
5 ODPOW. 5
profile.country.en_GB.title
tonybeard
On the PC that hogs all the bandwidth right click on the explorer icon on the desktop click internet properties and settings in browsing history turn down the disk space to use to 8 megs. This will stop the computer from drawing the bandwidth from the other computer do the same or increase the megs to balance the sharing. :slight_smile:
aalen
Thanks I will try
kee-lo_
Maybe your router has only got one port for WLAN use, what router do you own?
aalen
Netgear WGR614 v6
kee-lo_
Netgear WGR614 v6
It should be able to connect two wireless devices simultaniously.
Do you have the latest router firmware?
