hi,
I'm having problem with playing mp3s using Aeroplayer, these sounds OK on the PC, but on the TJ-35 it sounds like its jumping. I'm using dB powerAMP to convert the files, storing them on a MS pro MAGICGATE 256MB. Can anyone tell if its the sampling rate, software being used or something else? Or what software you use succuesfully to play mp3 on Clie.
thanks in advance
