Hi. I've deleted Clic to disk. I'd like to install it again. How can I do this. I figure that is in the hidden directory, but I don't know how to access only to that particular software
Hi spaceodissey,
most but not all of the pre-installed applications can be re-installed..
To do this click on Start, then All programs, then Vaio Recovery Tool, followed by Vaio Recovery Center.
Click continue on the User Account Control window..
A Vaio Recovery Center window should now appear.
Select Re-install pre-installed programs and click Start.
Click Next and Next again, then select the program you wish to reinstall from the list and click Next..
Then follow the installation wizard..
Thank you very much!
