Hello everyone!
I'm Andrea, I have a VAIO FW21E, my HDD failed and I had to replace it, I can't find my recovery disk at all, any chance some of you could upload it in here? Or wherever you prefer in case.
Or maybe if someone could tell me where can I buy it, as I am trying to find it on the internet but I can't find it.
Cheers!
Hi Andrea and welcome!
As far as I know the only official distributor is EET Europarts.
https://uk.eetgroup.com/search?query=Recovery
You will need to check for the correct discs for your particular Vaio. You may have to contact them as yours is an older model.
Hello and thank you for your quick response!
I checked yesterday night, there is no trace of any discs in the EET website for my Vaio unfortunately
You are right is a very old computer sadly
But it is my first laptop, a gift from my father, I really want to keep it going as it were
I've contacted the support I hope they will find a solution
Thank you anyway buddy!
