before installing windows7, I wanted to make recoverydisks. When I started the program to do so, after 8 minutes it said: "not able to write the disk". This happened both with the -R dvd as with the +R dvd (as the sony helpdesk adviced me to do). Anyone familiar with this problem and has a solution?
Hi icufrans and welcome.
I am afraid that this is a fairly common problem as notebook drives can be very fussy on media, but usually a different brand of media solves it.
I personally use Verbatim, but others have also recommended TDK and Sony Disks.
Hi icufrans,
welcome to Club VAIO..
What vaio model do you have as there may be an update available.?
Thanx both of you for the warm welcome and the prompt answers!
My Vaio is VGN-AWJ15-B.
I have not tried e different brand yet, will do so soon and will let you know.
Is it also possible to use a CD instead of a DVD?
Sorry for that, couldn't read my ownhandwriting, it's
VGN-AW315-B bought it in Amsterdam.
My recoverycenter says I need to use an DVD LD. I didn't use this kind of DVD's.
Ï found some Sony DVD's, they did not work either but they were not DVD LD. (What is the difference?)
Hi icufrans,
DVD LD could be referring to DVD DL (Dual layer).
I normally use TDK DVD+R when creating recovery disc's, however as Rich912 pointed out Verbatim and Sony also normally work ok..
Finally I succeeded! I bougth dual layer disk's and afters everal refusels: "can not write the disk" I kept on trying and now I have my recovery disk's.
Next step is to install windows 7 tomorrow.
thnx for all your support
You're welcome..
Something to think about - Once you've installed windows 7 you could purchase something like Acronis True Image and use this to create and store a backup image, use the following link for more information on: Acronis True Image
Depending on what you have created a backup of, you could restore your the Operating system, applications, user settings, and all your personal data in the event of a fatal system crash or virus attack to as it was when you created the image..
