The PSU on my desktop has become v noisy but does not take a standard size PSU. Anybody know where you can get hold of a PSU 100mm deep, 90mm tall and 165mm wide? Seems that these may be made to order for Sony. As an alternative, how easy is it to replace a fan in the existing PSU (by NMB).
Try eBay
hi
im not sure on this but just because the psu is a certain size doesnt mean that you have to get the exact same all you need is it to be the right power and the right connections,
kind regards ben
Ben the thing is it needs to be the same size or it won't fit in Sony's customised cases.
ohh yeah lol
im a little dumb
i think about my pc to much and just consider evereyone else's to be the same lol
if it is like the cd drive chassis theres a chance it could still be alright as inside mine it has loads of different screw holes that arnt even used ????? it also has holes all around the inside of mine like a string vest lol
i could basicly bolt anything anywhere aslong as it was able to get to its conecting point
regards ben
The main problem is the door.
why whats wrong with it is it jammed lol
try turning the handle
nah lol it is proberly best to get the same anyway as its like betting on last weeks lottery :smileygrin:
that would be nce to now last weeks numbers
:smileythinking:
maybe one day we will be able to astro project with a vaio mcfly machine
They have to be correctly aligned, or the door bangs into the chasis
i was messing around lol
and to tell you the truth i didnt know it even had a door i have only seen my psu attached and i am hoping that stays that way
do the doors not have screws or some sort of lache ???
No idea, I'm just saying what other members have told me about VAIO desktops and what I have seen in shops.
