- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Сони ВАЙО - проблем при стартиране????
Имам парола при стартиране на компютъра. Да преди 1 ден нямаше проблем, но сега ми изпраща съобщение "Потребителският профил не може да бъде зареден." И "Услугата User Profile Service не успя да влезе."
Какво да правя? Как да пусна лаптопа? Трябва ли преинсталиране?
Благодаря!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello az_mimi1000
Welcome to the Sony community. Unfortunately the fellow users here are only able to help in English. You could repost your query or if you need Sony's direct help you can contact them directly on: http://www.sony.bg/support/bg/contacts/vaio
Kind Regards
Clarissa
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a password when the computer starts. Until one day no problem, but now I send a "user profile can not be loaded." And the "Service User Profile Service failed to enter."
What to do? How to put a laptop? Should I reinstall?
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi azmimi2001, are you able to actually open windows if so then there are a couple of options you can try.
There is a registry edit that can be done or create another user account & copy the data across but this is only possible from within the windows environment.
