SONY EXTERNAL DVD-RW DRIVE - NOT RESPONDING
GIGGSY
Visitor
[ :((] I BOUGHT A SONY EXT DVD-RW DRIVE WHICH I HAVE ONLY USED ONCE BEFORE BUT HAVE NOW RECORDED NEW DVD THRU "MYDVD" BUT I CANNOT BURN TO DVD AS I GET AN ERROR MSG WHICH READS " H:\ IS NOT ACCESSIBLE , SPECIFIED NETWORK RESOURCE IS NOT AVAILABLE " ANY IDEAS WHY THIS HAS HAPPENED. THE ONLY THING I'VE DONE IS CONNECT DRIVE VIA iLINK CABLE TO REAR OF PC. PLEASE HELP:smileycry: :cry:
4 REPLIES 4
profile.country.en_GB.title
kee-lo_
Member
Restart the PC with the device not plugged in, then plug it in and see if that works.
I had a similar thing with a CD-RW
robpaxton
Explorer
And if that doesn't work then try deleting the IEEE1394 device from device manager. Reboot to allow the drivers to reinstall.
GIGGSY
Visitor
MANY THANKS KEE-LO- IT WORKED A TREAT. THANKS FOR REPLY AS WELL ROB.
MANY THANKS.
GIGGSY:smileyhappy:
kee-lo_
Member
No problem
