Hi my laptop keeps saying it has failed to connect to a windows service.
I am running windows 7.
Also my wifi does not work it will not detect and networks.
I have downloaded the drivers for the network card from the sony website but the laptop wont read the usb stick.
If you try to do something it goes slow and hangs up like it has a virious. When i do a scan it says no threats found,
I have set up some retore points and when i try to find them it says none found.
Is this a serious hardware problem or do i have to restore back to factory when the laptop was new.
Any help will be appreciated.
Thanks Lee,
Solved! Go to Solution.
Hi guys after a few hours of going through the hard drive, i have found a system restore and it is back to normal.
