Sony Vaio VGN-NR21Z win 7 Graphics drivers?
profile.country.en_GB.title
nharlow
Visitor
I believe this is the NR21Z/S model, about 2 yrs old
Anyway -
I decided to try and update Win Vista to 7 as an experiment and to play with a 64 bit os
It seemed to go fine until I installed a game and found that i only had the default graphics drivers so I looked for nvidia 8400M 64bit Win 7 drivers - since that is the graphics card.. nvidia drivers didn't load and so I tried the Sony site and couldn't find any,.
So 2 questions,
1) do these drivers exist and where are they (VGN-NR21Z, 64bit win 7 graphics)? a link would be nice
2) if they don't exist can I get a replacement setup disk (back to vista) as my original backups have had a small accident. ( think small daughter type accident). The hidden resource partition should still exist.
Thanx in advance
1 REPLY 1
Blencogo
I honestly do not know if it will work for you but it is probably worth trying to install the 64-bit Windows 7 nVidia driver released for the VGN-AW21Z.  I know the AW21Z has the 9300M GT nVidia graphics but it may install OK.
Graphics driver (nVidia) - 8.15.11.8640_0910130
You can download it from here - down the bottom of the list -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW21Z_B&os=10
:wink:
