Hi, I am trying to fix a Song Vaio VPCCA2S0E laptop. I canot get the webcam to work.
I have checked the sony europe support page and I cannot find a driver for the camera anywhere.
It coming up as a unknown device in the device manager. I tried uninstalling the device and reinstalling it and pointing it to C:\Windows\System32\drivers but still no luck.
If anyone can find a driver that will work or any other solution that will be great.
Many Thanks
SoulStrider
Solved! Go to Solution.
Hi SoulStrider,
To get the system to recognise the camera try the following:
In Device Manager, expand "Universal Serial Bus controllers” and delete all.
Then shut down and remove the battery/AC adaptor and press and hold the power switch for 30 seconds.
Re-attach the battery and AC adaptor and restart your computer. Windows will reinstall all USB controllers automatically and then hopefully the webcam will be recognised.
Rich
Hi SoulStrider,
Rich
