SVF1531C5E - VAIO Update no longer works
It says a new version of VAIO Update is avaialble and it cannot be used unless it is updated.
When I select to update nothing happens.
Sony what is going on here?
Solved! Go to Solution.
I have also updated VAIO UPDATE but i cannot restart my computer. Only long press on/off bottom helps.
I was contacted by a member of the Sony Support team and I can now confirm Vaio Update now works again for me also.
I am not sure how this is a solution the Sony Update Version 7.0.0.14270 does not seem to work for me; when I click on the titles it shows a 404 page error.
I have not been able to find an update for it either.
I have been quite disappointed with the user experience of the SVF15N1C5E - I do not feel like doing all the updates manually although of course will if I have to.
Regards
Hi sjm000,
You have the latest version of Vaio Update (7.0.014270) so I assume that it is just suggested updates do not download or install. Support is aware of the problem but if you can detail updates that do not either download or install this can be passed on to them.
Rich
