Hi all,
I have a new vaio FE41E since 2 week.
I have experienced many problems since then: club vaio tryng to launch and could'nt (fixed), Bluetooth not working even if i've installed the vista driver from belkin and...
I have a big problem with any usb device I tried to connect to my vaio. Every time it ask me to install new driver even if I'm plugging no driver needed device as my lacie external hd (I wrote to LAcie to ask it) or usb memory or wireless keyboard.
What can I do?? Anyone is experiencing the same?? I'm very disappointed to have bought this pc!!!
thanks in advance
Carlo (from Italy)
Is there any vaio expert that can help me??
thanks
Carlo
Hi carlo17,
I presume your Vaio came preinstalled with Vista right?
Why don't you try reinstalling your Vista again? Use your DVD discs - Might work, not sure though but you can give it a try.
THanks Hunch. I did it and now it works!!!
I did the recovery disks, do you know how delete the hidden pre installed stuff??
ciao
Carlo
