vaio blue clock screen saver
piratapirata
Member
Hi guys and gals,
I'm trying to transfer my old sony vaio screensaver that has been on my vgc-rc202 since 2006 but I can't remember the files I need to copy over, any ideas? It's the one that is a big blue clock that changes to an orange one.sony clock pic.gifsony clock pic.gif I've found 3 of the files in system32 but it wont work on new pc. it's sad that I've upgraded it to it's limit and I need to change pc totally. it's still running and the screensaver works on its latest version of windows 10. I did find a link but it was dead. I don't remember it being on the original installation disks but as it was xp i doubt it would help. thanks for any help in advance.
2 REPLIES 2
Blencogo
Hi piratapirata
Sadly, as these screensavers are written using Adobe Flash, they will no longer work on the latest builds of Windows 10.
I believe a Windows Update in October 2020 removed Flash functionality in Win 10.
Sad I agree!
piratapirata
Member
Thank you😊 That's one thing I suspected but I can't understand why it's still working on my Vaio eventhough it's been updated to the latest version of Windows 10 this month? I still suspect I'm missing a file that is not called "Vaio screensaver". The other possibility is that my Vaio window is 32bit and my new pc is 64bit? It would be great to find a way of posting the files here also if it worked. Thanks for your suggestions.
