Condividi la tua esperienza!
My K215z has a big problem with the speedstep and i think is a common problem for the K series.. if i use the battery my laptop should work at 1.6Ghz and it works at 3.06Ghz.. i have to restart my computer to work properly... does anybody knows how can i fix this?
Thank you.
It's a Pentium4 mobile, which supports only 2 steps.
Full speed and low speed. Or 3.06 and 1.6GHz on your VAIO.
A Intel Centrino CPU supports 6 different steps.
HTH
Hee Hee, Good Luck.
I like that smilie GBS
HTH
Mmmh,I have no idea. But lol, my english isn't much better.
sony doesnt do anything to please the customers.. lack of support ... too bad for those very beautiful laptops..
also the battery power meter is not good it doesnt shows the remaining time acuretly..
Think this has been posted before and the concensus that it was an Intel bug.
Yeah..next time when I will buy a notebook.. it will be a TOSHIBA or HP, even to my friends i wont recomand VAIO.
How about the battery meter time do you know something to fix this issue?
