- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Vaio Sony VPCL12M1E Power supply Fan speed Error
Hello guys, I Have a big problem with my Vaio Sony VPCL12M1E.
When I turns on the computer, the computer turns on normaly.
But 3 second after
"Power supply FAN Speed Error.
Press F2 Key to enter the BIOS Setup
The system shutdown after 10 second"
I Really need help guys !!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Blooodz and welcome
Unfortunately, it could be many things.
Going into the BIOS will probably only allow you to turn off the error message or lower the value of the fan RPM that triggers the warming. This would allow you to use the Vaio but won’t cure the problem. This is only possible on some Vaios as Sony restrict some BIOS functions.
It seems likely that the cooling fan is not spinning up quickly enough and this needs checking. Often dust will build up and restrict free movement. You could try gently blowing compressed air into the cooling vents but a better solution is to open the case and clean the air vents and fans.
Occasionally, the fan bearings may be worn or the fan failed and this would need to be replaced.
Good Luck!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem - but it is clearly connected to the addition of additional memory - add the memory and the fan speed errors appear - remove it and they go away! No bios settings to change. Help? One useful thing - if you hit <F1> befoe shutdown it proceeds to the boot step.
